ScottK
@jlglr4- in hindsight I definitely should have done then. I had that done at the indie. When I discussed replacing the front with the dealer they recommend or more like insisted
that they replace the water pump at the same time. I’m sure that is probably a good idea seeing that is a key component and the high mileage. Your thoughts? Anything else glaring that I should replace at 100K? Thanks.
