maintenance history since new 2013
ttforcefed
Holding strong
ttforcefed
4 years and 60k miles, $43k
10/14/2021123,387oil, differential fluid, lower cntrl arm and joints, alignment, ATF was clean2,284
2/24/2022126,035oil, timing chain, water pump, coolant system, belts, plugs7,593
6/12/2022132,473oil, AC service569
10/31/2022137,844oil, coolant, alignment800
11/29/2022140,508universal joint steering, tranny service1,291
3/3/2023145,008oil162
7/7/2023151,662oil162
8/11/2023152,000y pipe, alternator, battery, new pad sensors, front and rear brakes4,958
8/14/2023153,138fuel flange recall, fuel leak460
9/27/2023155,245oil162
12/1/2023156,600replace power steering pump, replace rear calipers/hoses, 4 wheel alignment, oil change2,812
2/10/2024161,675oil850
2/23/2024161,706oil, replace vacuum pump with seal, crankcase breather diaphragms, cleaned intake and throttle body, new plugs2,206
4/17/2024163,726ABS wheel speed sensor459
6/1/2024165,149oil,replace oil cooler, sunroof drain, rear wiper, replaced MAF, replace cig light, replace start stop button.2,562
6/2/2024166,000CarPLay1,150
9/13/2024170,210oil, check egr809
11/18/2024175,100oil, new tires, replace coolant tank, replace lower control arms, cabin filter, radiatior, heater hose, intake vacuum solenoid7,883
5/1/2025180,000replace front wheel bearings, oil, front and rear diff fluids, xfer case and tranny fluids. Relpace tensioner, drive belts and pulleys5,848
powershift
Nevada
Nice list. Great price on the timing chain work. For your front wheel bearings, what were the symptoms or was there any symptoms of failing?
ttforcefed
A pretty noticeable whine coming from the front over 30 mph that sounded a lot like a differential going.
