ttforcefed
- Joined
- Dec 19, 2010
- Posts
- 652
- Reaction score
- 205
no pinch from the install. They replaced the whole part
10/14/2021 | 123,387 | oil, differential fluid, lower cntrl arm and joints, alignment, ATF was clean | 2,284 |
2/24/2022 | 126,035 | oil, timing chain, water pump, coolant system, belts, plugs | 7,593 |
6/12/2022 | 132,473 | oil, AC service | 569 |
10/31/2022 | 137,844 | oil, coolant, alignment | 800 |
11/29/2022 | 140,508 | universal joint steering, tranny service | 1,291 |
3/3/2023 | 145,008 | oil | 162 |
7/7/2023 | 151,662 | oil | 162 |
8/11/2023 | 152,000 | y pipe, alternator, battery, new pad sensors, front and rear brakes | 4,958 |
8/14/2023 | 153,138 | fuel flange recall, fuel leak | 460 |
9/27/2023 | 155,245 | oil | 162 |
12/1/2023 | 156,600 | replace power steering pump, replace rear calipers/hoses, 4 wheel alignment, oil change | 2,812 |
2/10/2024 | 161,675 | oil | 850 |
2/23/2024 | 161,706 | oil, replace vacuum pump with seal, crankcase breather diaphragms, cleaned intake and throttle body, new plugs | 2,206 |
4/17/2024 | 163,726 | ABS wheel speed sensor | 459 |
6/1/2024 | 165,149 | oil,replace oil cooler, sunroof drain, rear wiper, replaced MAF, replace cig light, replace start stop button. | 2,562 |
6/2/2024 | 166,000 | CarPLay | 1,150 |
9/13/2024 | 170,210 | oil, check egr | 809 |
11/18/2024 | 175,100 | oil, new tires, replace coolant tank, replace lower control arms, cabin filter, radiatior, heater hose, intake vacuum solenoid | 7,883 |
5/1/2025 | 180,000 | replace front wheel bearings, oil, front and rear diff fluids, xfer case and tranny fluids. Relpace tensioner, drive belts and pulleys | 5,848 |
Nice list. Great price on the timing chain work. For your front wheel bearings, what were the symptoms or was there any symptoms of failing?4 years and 60k miles, $43k
10/14/2021 123,387 oil, differential fluid, lower cntrl arm and joints, alignment, ATF was clean 2,284 2/24/2022 126,035 oil, timing chain, water pump, coolant system, belts, plugs 7,593 6/12/2022 132,473 oil, AC service 569 10/31/2022 137,844 oil, coolant, alignment 800 11/29/2022 140,508 universal joint steering, tranny service 1,291 3/3/2023 145,008 oil 162 7/7/2023 151,662 oil 162 8/11/2023 152,000 y pipe, alternator, battery, new pad sensors, front and rear brakes 4,958 8/14/2023 153,138 fuel flange recall, fuel leak 460 9/27/2023 155,245 oil 162 12/1/2023 156,600 replace power steering pump, replace rear calipers/hoses, 4 wheel alignment, oil change 2,812 2/10/2024 161,675 oil 850 2/23/2024 161,706 oil, replace vacuum pump with seal, crankcase breather diaphragms, cleaned intake and throttle body, new plugs 2,206 4/17/2024 163,726 ABS wheel speed sensor 459 6/1/2024 165,149 oil,replace oil cooler, sunroof drain, rear wiper, replaced MAF, replace cig light, replace start stop button. 2,562 6/2/2024 166,000 CarPLay 1,150 9/13/2024 170,210 oil, check egr 809 11/18/2024 175,100 oil, new tires, replace coolant tank, replace lower control arms, cabin filter, radiatior, heater hose, intake vacuum solenoid 7,883 5/1/2025 180,000 replace front wheel bearings, oil, front and rear diff fluids, xfer case and tranny fluids. Relpace tensioner, drive belts and pulleys 5,848
A pretty noticeable whine coming from the front over 30 mph that sounded a lot like a differential going.Nice list. Great price on the timing chain work. For your front wheel bearings, what were the symptoms or was there any symptoms of failing?
