Door deadening
Jimmy Brooks
Pasadena California
if I do dynamat the tailgate where are the best places to hit. Should I do the out side over the sub guard that isn’t pushing air through or just the inside and every where on it. Also should I cover up unnecessary holes, is it an open air sub or a enclosed compression sub
THE biggest difference is to dynamat your tailgate for the sub. You will get better response and actually hear lower frequencies.
Oh, why didn't you pull the speakers and dynamat the inside of the doors? That's where the magic happens.
It's somewhat an open air sub with a semi sealed enclosure. It doesn't have to be air tight, but dynamating the inside (behind the sub) and a single layer top will do a lot of good.
Tapps33
Bath, Maine
I meant to ask, where did you get all your plastic pins for the doors/door cards?
Also, I may have read it wrong, but you mentioned rubber seal? Was that already in the door, or did you add it? Sorry, I haven’t taken the panels off this vehicle yet....I figure it’s better to order the parts ahead of time because I really HATE having to put something BACK together only to tear it all apart when the parts arrive. [emoji28]
Thanks!
Tapps33
Bath, Maine
Thanks!
Jimmy Brooks
Pasadena California
there were some unnecessary holes on the doors that I covered up with duct tape assuming it is a closed air system. Here are a link to the clips, just a tip they come one clip per pack.
https://parts.landroverftmyers.com/...e--5-0l-v8-gas/body--interior-trim-front-door
Thanks!
Jimmy Brooks
Pasadena California
Sorry for the long awaited response. That’s a great project and I’m really excited to see how it works out. Maybe I’ll have to do the same as you have! Anyway yes I was. There’s easily enough accessibility to get the whole inside of the door. I didn’t do much inside the door due too the fact that I didn’t want to mess with the massive moisture barrier and have a problem wading through a river so I just did as much as I could access through the speaker mounting. I just did the sub a couple of days ago and did inside and out of the tailgate. I noticed quite a bit of difference especially in rattle situation. Over all I’d say the project was much worth it.
Wow, thanks for the write up! I’m actually a few months away for several modifications/upgrades to my 2010 LR4 as well. I did just bit the bullet and bought the 825W amp for a 2012 system to install, and then I plan on retrofitting AudioFrog speakers into the vehicle to make sure they can handle the extra power....and sound better in the process. That said, I really need to dynamat while I’m in there too!....I also need to rob a bank to afford all the new speakers too, but that’s a who different thread! Lol
Out of curiosity, we’re you able to get inside the doors at all? Or did you just do the outside of the door/inside of the panel?
Any plans to do the tailgate sub too?
Awesome job by the way!
Land Rover Joe
Oxford
Thanks for the great write up @Jimmy Brooks !
How do you like the install now?
I am planning on doing some work like this so looking for any tips, tricks, and advice!
powershift
Nevada
That dynamat looks great. I didn't think of applying it to the plastic door covers, clever.
I was thinking to install a JL Audio 12" sub in a removable enclosure, but I can't find the link to it anymore. JL Audio gets redirected to Garmin and then they don't show their $2k subwoofer drivers anymore. But some of their drivers were high quality and with 600+ AMP monoblock powering it, the LR4 would hit pretty hard. It might even blow the windows out lol.
