AC not cooling - B11FF-85 (2E) code
M32H32IS
Texas
I had an issue like this last summer. I had my compressor and condenser replaced and everything. Worked perfect for a couple of months and then this happened. They replaced the HVAC control module and that solved it.
What is the hvac control module?
Asilver
New York, NY
Having similar issues. Compressor was replaced last year and I’ve just replaced it again. Compressor comes on then shuts off. New HVAC Module just installed as well (second hand) but no improvement. Two different shops are at a loss now. I’ve got one other shop to try but hoping to learn something here to help point them in the right direction.
powershift
Nevada
The owners manual says to run the AC weekly. Not sure if any of the failures could have been prevented by usage but its an interesting maintenance item.
M32H32IS
Texas
Houston, TX so yeah it gets used 11 mos out of the year
powershift
Nevada
Yeah, plenty of use there. In Vegas my AC seemed worthless. But realistically I'd probably die on the freeway in traffic without it. The pavement gets super hot and all the heat its partitioned by jersey barriers and then the slow hot cars along with the blistering heat of the sun. It his 120F each year except this year it hasn't been that hot for whatever reason. This year has been a nice break.
