Jimmy Brooks
I'm curious about your swaybar maintenance. I think I hear a slight squeak noise in the front right when off-roading but its so faint its hard to tell where its coming from. Were there any noises or symptoms that the swaybar end-links or bushings were going out?
Sway bar links are usually more of a knocking kinda noised. The sway bar mount bushings are more of a squeak. If you go under the car you should be able to see if they’re deteriorating or not. Some times they’ll be in such bad shape that you can pull the rubber apart just by picking at it with your hand. If you’re constantly off-roading it wouldn’t surprise me if that was the case.
It could also be control arm bushings, my rear upper control arms were making a squeaking noise pulling into driveways because the bushing was destroyed. When I replaced the arm it went away.
