'00 Disco2 intermittent start problem
leej
Hi all
I have a 2000 Discovery II with 80,000 miles on it. I have had it for about a year, and it has been running fine.
However, it is having a starting problem. It will crank fine and turn over good (strong battery), but acts like it is not getting gas or spark. Then, all of the sudden, it will start, and run just fine. No error codes.
I can't tell that there is any pattern (i.e. does it when hot or cold), and I'm not sure if it is a ignition or gas problem. Any ideas?
I was going to test for good spark by pulling a wire, but read on one post that this is not a good idea; any suggestions on testing for spark? I have seen posts regarding a crankcase sensor, and posts for a fuel temp sensor, but nothing on how to diagnose.
Any help would be appreciated. Let me know if you need more info. Thanks.
Lee
2000 Discovery 2
greg409
Over a 3 yr, period, both my LR's had intermittent start problems, and in both cases they sometimes didn't want to restart after a short trip ie. grocery store.
If I let them sit for 10 - 30 mins. they would restart and run fine.
In both cases a $75 crankshaft position sensor from the dealer resolved the issue.
luck,greg
leej
Sounds like the consensus is crankshaft sensor... Should I have received any ODB codes on this?
I wish there was a way to test or diagnose (other tham simply replacing).
Lee
No codes just starting issues
leej
Thanks for the advice. I have ordered the crank position sensor from Atlantic British, and will report back once I replace the old one.
Hopefully it won't be to hard to locate and replace. Any advice on where it is or tips on replacing would be appreciated. Thanks!
Lee
2000 Discovery
There are 5 fault codes for a failing crank sensor but they rarely show up.
greg409
It's well hidden against the engine, under the driver's exh manifold, covered by a shield. bolted against the rear of the block, facing the trans. (whew)
As I recall, my weapon of choice was a 1/4" drive, 6" ext, topped with a 7/32" six point socket
It's in the free rave cd
luck,greg
leej
Greg, thanks for the advice. I am waiting on the replacement sensor (ordered yesterday), but I crawled under this afternoon and I can see the crankshaft sensor cover, and I think I can barely reach it once I get the truck up on some ramps (won't be easy), but I'm worried about being able to reach the connector... We will see...
greg409
Naturally, wear long sleeves or let the engine cool down, as I recall
luck,greg
