Hi Everyone,
I Own A 1998 Range Rover And Have A Problem With My Abs System. The Pump Keeps Cycling On And Off Every 5-10 Secs Even Without Using The Brakes, Causing The Pump To Overheat And Eventually Burn Out. I Have Burned Out 2 Pumps Before I Investigated And Found Out The Reason. Would Appreciate Any Advice From Anyone Who Has Solved This Problem. Could It Be A Bad Accumulator?
