Battery Profile Setting
Nechaken
Colorado
I just replaced my battery with Bosch H7 AGM 80 Ah 800 CCA battery.
In the IIDtool, there's a H7-80Ah-700CCA profile as well as a generic (no "H_") 80Ah 800 CCA profile.
So obviously the 80Ah 800CCA profile more closely matches my battery but I'm wondering if its a problem that it doesn't have the H7 in front?
Does the "H" series correspond to AGM battery which I presume has a different charging profile than a standard lead-acid ?
(I also see there's an H8 90 Ah 800 CCA profile. Not sure if the amp-hour capacity or CCA instantaneous delivery matters more.)
Nechaken
Colorado
Oops, had a typo. The available profiles are the "H7" 80 Ah 700 CCA and non-H7 80 Ah / 800 CCA.
djkaosone
'11 LR4 HSE LUX 5.0L V8
SoCal
H7 or H8 is just the battery size and has no bearing to Ah and CCA. Just choose the 80 Ah / 800 CCA.
Azoo
Brampton Ontario
I changed my battery 2 yrs ago and i did not do anything else. Just took the old one out and connected the new one and no issues to date.
Quijote
Metro Boston
I used the IIDTool when I replaced my battery and I do not recall seeing any options.
bbyer
Alberta
Battery Profile? I am wondering what that means?
I have an LR3 so I know nothing about "battery profile" but I wondered what that means.
On my 3, all I know is that the "smart" regulator in combination with the engine computer is pretty dumb when it comes to keeping the battery fully charged - well it does not, maybe an 80% state of charge is the best it can do.
I wondered if perhaps the 4's charging systems were a bit "old school" or at least had that option such that the battery could get closer to a 100% state of charge?
Nechaken
Colorado
So, in addition to the reset/replace battery function, there is also in the BCM area a battery type setting. I am presuming the car is keeping track of charge level vs drain and uses this information to decide what kind of charge profile to supply...
