quirozson
465mm is correct for front height from hub centerline to lower wheel molding edge.
I show 170NM for front axle nut torque for 2010-2013. This is what I used when I changed my front hubs, and I have no issues to report.
I do not know if the torque figure changed for later year models.
I found a SKF publication that puts the torque for the axle nut @ 169 fit-lbs and/or 230 Nm... On a side note, the rear axle nut is 311 ft-lbs!
