getting ready for 60K maintenance...
2002DiscoII
I've ordered spark plugs, plug wires, air filter, oil, and oil filter....is there anything that I should be aware of for the 60K maintenance before jumping in there? I am going to do most of the service myself and then take it to the dealer for the rest.
Thanks guys!!
I would also change the Transmission fluid, Diff Oil, Transfer case oil, and Antifreeze and hoses. Check the front driveshaft for any play ... unless you have an upgraded shaft and it has grease fittings.
2002DiscoII
is there still drive shaft issues on the 2002? if so, what is this upgraded drive shaft and where do you recommend purchasing this from? Is it a labor intensive install?
MrRodgers
