Head Gasket replacement
discovervaacd
Greeting new at this forum but from my initial reading there's alot of valuable info flowing.
Had a coolant issue and found a fault had gasket.. as the truck sat until I could get it repaired I noticed that starting "running" required warm-up time to get idling correctly. Then there was a power issue.
What's been done so far:
Head Gaskets replaced
Fwd O2 Sensors replaced
Coil pack replaced "miss firing 2 and 4"
New plugs
Now:
Still now getting the power out of the engine
Q: Fuel Press @ idle.. what is that press suppose to be?
Q: Air Flow Meter.. is it possible that backfiring as damaged that circuit?
Q: Air Flow wiring.. found wiring frayed, wiggling the wiring effect the engine running but not the extent of running correctly.. Wiring diagram would be nice.
I don't have a manual.. would like to know where I can download manual info?
Appreciate all the experts advise.
Audie
SulliMtn
