Headlights
dumhuve
Only highbeam works on right (it's not the bulb) what's usually the cause?
How do you know it is not the bulb, have you checked both fuses?
greg409
you've already pulled the connectors (clean?)
& of course you've checked for voltage to ground @ the connectors.
If the fuse(s) are good, you have voltage, connectors are clean, then your bulbs are burned out. (two low & one high)
don't know where the headlight relay is, but since one bulb half works, I'd suspect that last
the rave cd has great wiring diagrams & descriptions of operations.
luck,greg
Rome0Mike
