M
mconnet
I'm trying to figure out if my billy goat (2005 LR3) will safely pull a 30' long, 7,100 lb. (dual axle with brakes) travel trailer.
The LR3 is factory rated at 7,700 lbs. total weight and 550 lb. tongue weight.
I'm told that when pulling a trailer the tongue weight should fall within 10-15% of the total weight, which would imply that the LR3 should pull no more than 5,500 lbs. Apparently too low of a percentage can cause sway. I also understand that perhaps Sway Control bars can reduce or help control sway. Finally, I understand from other posts that you can not use a Weight-Distributing Hitch on the LR3 because of it's air suspension system.
Does anyone know what this biily goat can really do? Has anyone had any experience towing a large travel trailer?
Thanks in advance.
Thanks in advance.
