New Recall Alert : Fuel System
powershift
Nevada
Yeah, it was hot for the time but beautiful. I think the warmer gas in the tanks might have been triggering the symptoms. The recent heat wave record we had the other week of 5 days of all time record breaking heat I jumped into the CO river while it was up since that is where I buy gas, bunch of snow melt up river now.
You can drive right up to the river and drive along it too if you wanted in AZ. Its fun to position it to chill for a bit and drop the suspension to show off the LR4 lol. Yesterday there was an offroader there but a wind system was coming through. Another benefit to access mode is to drop the suspension and chill on the down-wind side. Can't do that in a traditional spring'd 4X4 because its all open except where the tire is but that isn't enough.
theegovernor
denver
That is a great deal, thank you. I did notice there are quite a few PN's but the way I'm looking at it is hopefully there is only one Purge Control Valve per vehicle mounted near the engine valve cover and the wizard on that site verified it fits my year/model. I did a visual part and picture match for LR010806 so as long as the website I was looking at had correct information then then LR172646 is the latest revision. That is something I didn't think about with the Ebay option. That used part while functional and inexpensive could be outdated where new fixes are built in later part revisions making it stronger. At least that is what I'd like to think, they could potentially do that if they wanted to lol.
fyi it looks like this ford part can be used to fix this issue instead of getting a whole new assembly. I am installing one. Part C1BZ9C915A
powershift
Nevada
Nice find. I paid over $200 for mine but it also had the tube and connectors on it.
mm3846
LI, NY
I attempted this with a cheap aftermarket piece but couldn’t get a good seal with the ends. They’re that shrink-plastic and when I tried vacuum hose and clamps they still leaked.
shinckley08
Boise, ID
I am going through something similar and think a smoke test is in order. @mm3846 you seem knowledgable on this topic, if I have the equipment is the test something I can do myself? I think Im able to get it as a loaner from a local parts store.
I had a fuel smell, pretty cosistent when the temp got over 90ish F. I put a new fuel cap, having some other issues with trims and thought that the purge valve should be replaced, so I did that. I had no codes related to evap and this smell situtation went on for almost 2 months.
I attempted, with poor info, to replace the canister and DTML pump, and failed not knowing I needed to lift the body from the frame to get it out, so I put the new pump on and buttoned it back up, then was getting P0441 and P0442.
I had it in to Land Rover for the tank flange recall, I cleared the codes and drove for three days with no codes, but the fuel vapor smell remained. Three days later I replaced the canister, the DTML, and the DTML gasket/o-ring, I inspected all the connections and cleaned and lubricated all the seals when installing.
Now Im getting the P0442 and the smell is still there. It seems to come from the wheel wells and is stronger on the passenger. Im assuming at this point I must have worsened the leak, wherever it is when doing the work.
Those discussing here seem pretty knowledgable
mm3846
LI, NY
I can’t remember what I wrote here, but the smoke test didn’t prove much because you can’t manually control the purge valve via the computer to test it. If I member right, I just replaced it bc at that point it was the only thing that made sense.. and then I found out about the updated part.
VelarSupercharged
