Outfitted LR4 and Towing
bdd123
USA
Are any of you running a fully outfitted LR4 and towing?
I wonder what will happen to my towing ability if I put on front (with winch) and rear bumpers, sliders and all underbody protection.
Usually, when I am out, I have a fridge in the rear, miscellaneous gear used for survival, and at least overnight capability. Probable 250lbs ish. I generally travel solo.
I can still tow a 5500 lb trailer pretty darned well. I am wondering how all this junk would jack my towing. I don't really want to shuffle stuff from trailer to LR4. What is in the LR4 needs to stay there.
Would probably end up with 265/65R18 tires as well.
Any practical experience?
powershift
Nevada
Not I.
I've read a lot of threads on it and found the 550# tongue weight can increase to 770 lbs with a proper hitch. I wouldn't do it with the aftermarket shocks though. It has a 4k rear end in it. Look at the F-150 and its a lot like that but far better with an IFS/IFRS, air shocks with shorter and narrower foot print.
I wouldn't go over the axle and tire weight ratings for very long. Maybe a few trips but not in a case where I buy an RV that is far over max and then expect to travel the country with no problems.
mm3846
LI, NY
GCVW - all the bolted on **** = your new GCVW.
Tongue weight is 550lbs max per the manual.
bdd123
USA
Yeah, I will run those numbers when I get info from tactical. At this point not worried about tongue.
Also interested in experience. Without aftermarket gear whole setup works great.
Using weighsafe distribution hitch.
landylou
