P0327 code, 2015 LR4 53k miles
Pkoss
Annapolis, MD
Hi forum,
I have a 2015 LR4 with 53K miles with up to date maintenance and recently had a CEL with the P0327 knock sensor code. Truck ran fine with no apparent knock and checked the sensor lines so cleared the code. It ran fine with no CEL for 5 days and now it’s back again. Anyone run into this code before? Any tips on resolving? Thanks!
DaytonaRS7
what fuel do you use?
low grade or bad fuel is the first thing id check.
fill up with good (premium) fuel or put a fuel additive in.
Since it ran fine for a few days with no code, id assume to rule out the sensor as being bad. the code would have come back immediately if that was the case.
Pkoss
Annapolis, MD
Thanks, Daytona. I always use premium and use Shell vpower pretty exclusively. Recently added Lucas fuel treatment and the CEL turned on 50 miles after so don’t know if that could be related. Any other insights?
avslash
The Lone Star State
Just spitballin' here.
Intermittently failing sensor
Bad injector causing lean condition
Dirty throttle body causing lean condition.
