Reliable Independent Mechanic in Los Angeles Area
serge1060
Lancaster, CA
Hi,
My 2012 LR4 is having oil leak and could not identify where it is coming from. I need a recommendation for a reliable independent mechanic to diagnose and fix the leak. I have been doing regular oil and filter change every 4,000 miles or less and recent oil change, I added Archoil AR9100 for the valve clicking which somehow helped. The oil leaking happened after my last oil change with an additive. I would appreciate very much your help. Thank you.
wallyyfm
NoVA
Absolute on Hoover used to be good back in the day. May be pricier, check reviews for the latest.
Fuji4
I use Jomag auto on rowena for most things (brakes, oil, crossovers, LCAs, pumps, fuel sender, belts, pulleys, a/c, transmission zip kit and fluid changes, etc) . I use
Independent Landrover Complete Auto Service​
in glendale for complex (read dealer level electrical or hard to diagnose) issues. ILCAS is more expensive, higher end, dealer level service. Not that pricey, but not cheap.
2010 LR4 Rick
Pasadena, CA
Hi,
Pasadena Motor Cars. They’ve been keeping my 2010 LR four going for the past 220,000 miles with no major issues. They are family owned and factory trained.
