Slips in park
jusjay
Hi guys, my disco slips or rolls after it is placed in park. Its a 98 Discovery with 101,000 miles. No other issues or sounds coming from the transmission. Is there a way to adjusted the parking pawl mechanism?
This is a new one on me... if it is slipping in park this may sound like a rebuild or start using the parking brake.
97rover
There is a pin the size of a #2 pencil that holds the vehical in park. Unfortunatly it is inside the trany. That also means if it is broke or sheered off it is also rolling around in your tranny. I would have it looked at by a tranny pro.
jusjay
Thanks guys, I was worried that would be the answer. I can get to the park system by removeing the transfer case and the then the back section of the transmission. I really did not want to do this, guess I will just start using the parking brake!
Jay
Remember as 97rover stated... if it is broke, something is floating around in there somewhere... the question is when will it cause other issues.
97rover
Just a good reminder to all. Always use your parking brake. The pin that hold you 3000+ pound vehical in park and to stop it from rolling is only the size of a #2 pencil. Even if you are on a flat surface. It doesn't take much for it to start rolling.
Slytrellis
