U
Unruely
I have a '94 D1 with 148,000 miles on it. i just bought it about 1 month ago and have dome some tune-up work on it. Last week it started having a strange misfire problem, i thought it was just the injectors which needed replaced anyway. I changed the injectors this weekend but am still having a problem. It will start instantly when it first cranks over and seems to idle fine for a while. I have about a 10 minute drive out a side road before i hit the main highway. I'm running about 25mph max until I hit the main road, if I have to sit at the intersection for more than a few seconds it starts running rough. When I pull out on the road it feels like I'm only running on 5-6 cylinders, very rough, coughing shudders until I go a little ways to about 40mph... Then it is like someone throws a switch and throws me back into the seat and really takes off.. If I have to stop again the same thing will happen?? So far the work I have done is this: changed plugs (Autolite platnium), wires, rotor button, distributor cap, all 8 injectors, ran half a can of Seafoam thru it, and cleaned the stepper motor. I have a bad exhaust leak in the Y pipe i need to get fixed soon, but would like to diagnose this problem first. I'm wondering about the coil or module?? Really just don't know what to do next?????????
Martin
Martin
