sunroof leak
G
gillboy
Major rain leak on disco 2 front sunroof every time it rains. Both sides of ceiling are soaked, water coming out of rear view mirror. Suggestions?
Moose
On a D1, and I assume D2, there are drain tubes. Yours are probably clogged. Open the sunroof and look for holes -- cleaning them with compressed air or a long and flexible wire will probably do the trick.
Also check to make sure the screws that hold the glass in place are tight... they work themselves loose and will cause a leak too.
STQAddie91
