(UPDATE) First Winter with the girl and...
Michael Conley
New Jersey
Hell of a way to find out lol
Michael Conley
New Jersey
Engine fuse box slot 15 doesn't have terminals for the fuse, only slot 18. Any run into loose terminals before?
Michael Gain
Clarksville, TN
There have been those that have found disconnected ribbon cables underneath the driver-side a-pillar trim. If I remember right, one screw is located under the SRS cover and then it pops off. Google to verify though..
Michael Conley
New Jersey
So I went blindly by the manual and didn't bother to look under the engine fuse box cover. Lo and behold the windscreen heater fuses are 40A and located in a completely different location. Further research uncovered a service bulletin stating that the windscreen requires 40A fuses instead of the original 30A. Will try and swap tomorrow and see if this proves if, hopefully, I just need a new fuse.
Bethesda, Maryland, USA
Interesting, is this the first time on the forum we've heard about a TSB on this fuse change? Maybe I missed something. I thought we just had a discussion about the risks of going from 30A to 40A; in fact I'm sure we did.
I keep mine in a garage 99% of the time unless I'm visiting poor relations who don't have an available spot for me (JUST KIDDING) but still like to stay on top of stuff like this.
Michael Conley
New Jersey
Update: Looks like mine was retro fitted with the 40A fuses for both sides (notice the sticker over FL1 to FL8). They're a pain to pull (already cracked the top off one) so going to buy a couple before I continue with the swap.
Michael Conley
New Jersey
Someone posted a while back, looks like the TSB was never fully launched due to inconsistency?
https://www.landroverworld.org/threads/window-heater-fuse-issue.25093/
Or they didn't want to deal with melted fuse boxes. 40A is a big fuse.
Michael Conley
New Jersey
What's that about a melted fuse box? @____@ Bottom ribbon connector, popped the trim and started smelling burnt plastic and here we are
¯\_(ツ)_/¯
Wondering if the fatigue in the ribbon cable is responsible for the short...
