2010 LR4 Headlight problem / weirdness?
nashvegas
Random thing has happened 2x on our 2010 LR4 HSE Lux. Truck has high beam assist. Anyways, driving at night on the highway -- now twice -- cold weather -- a few weeks apart, here's what happens:
I hear a click down in the passenger front footwell area
Front lights actually go OUT for a sec and come right back on
Truck makes some warning beep
The dynamic headlight lamp comes on and blinks until you restart the car (its green)
Everything then works as normal but the headlights don't swivel when you turn around corners.
Any ideas ?
Red Landie
If I remember correctly, the fuses and circuit breakers are located up under the passenger's footwell. That clicking sound you are hearing may be a circuit breaker opening or closing.
baobay
Yes that's where the fuses are located. I bet it is a fuse issue or some sort of electrical problem. The lighting system in the lux with vision assist is pretty complex.
baobay
Any ideas ?
Did you change a ny bulbs yourself or disconnect the headlight assembly? If so, the dealer may need to reprogram the active headlight feature.
horacioad
Any ideas ?
Short? Poor fuse connection? Have you tried pulling the fuse out and/or replacing it?
nashvegas
Update: additional problem
It's done it 2 more times. And also, I noticed that the LED lights under the mirrors (puddle lamps I think they're called) no longer work (at all). To the dealer we go.
Jobaker4
Exact same thing happened in my 2011 HSE Lux with vision assist! Please let us know what you find out. So far has only happened once to me but it was in the bitter cold too...
waltzonice
I've had the Adaptive Front Lighting System warning lamp come on twice in the last couple of months. It would stay flashing until the next start of the car. I took it to the dealer and of course they say they can't reproduce the problem.
How do you tell if the Adaptive Front lights are working or not?
baobay
You can see the lights turn when you're driving at night.
