IID tool and TPMS
roverman
Could somebody with IID tool please tell me what the settings are for TPMS? Mine isn't showing up on the dash, I tried to restore it but no dice.
Thanks
roverman
Anyone? Gap team told me:
Leave TPMS 1 alone
set TPMS 2 to "TPMS fitted"
Problem is that it still doesn't seem to work. My TPMS 1 is set to WMB (I think) but I don't know if that's right and haven't gotten an answer yet as to what it should be.
This is all under "menu---car config---body control
It's not the end of the world, I drive without it 8 months a year when I run my BFGs, just wouldn't mind getting it figured out.
Thanks
LR4USN
I have LR3-08 and have tried a few times to reactive my TPMS and each time it fails to load with an update error. I got tired of fiddling with it.
Venice Area - Italy
WBL/TPMS fitted on my 2010 LR4
Could you be more detailed?
Sorry for my phrase but there are a lot of choice on CCF items, could you check which one?:
Or do you mean the green coloured text item?
BY BBS data base (83331 vehicles analysed, red text)
- Without monitoring system (66% of vehicles)
- Monitoring system TPMS H without WBL, ICM reset
- Monitoring system TPMS without WBL
- Monitoring system TPMS H without WBL, ICM shut-off
- Monitoring system TPMS with WBL
- Monitoring system TPMS H without WBL, full ICM function
- Deflation detection system
- Monitoring system TPMS with TIRE PRESSURE SENSORS-4WHL, NOT FOR VCC
- Monitoring system TPMS With WBL, HSPA, No WT, No DLS
- Monitoring system TPMS With WBL, HSPA, WT, No DLS (3% of vehicles)
- Monitoring system TPMS With WBL, WT, No HSPA, No DLS (18% of vehicles)
- Monitoring system TPMS With WBL, No WT, No HSPA, No DLS
- Monitoring system TPMS L without WBL, no ICM function
- Monitoring system TPMS L without WBL, ICM reset
- Monitoring system TPMS L without WBL, ICM shut-off
- Monitoring system TPMS L without WBL, full ICM function
- Monitoring system TPMS With WBL, HSPA, DLS, No WT
- Monitoring system TPMS With WBL, HSPA, DLS, WT
- Monitoring system TPMS With WBL, DLS, WT, No HSPA (13% of vehicles)
- Monitoring system TPMS With WBL, DLS, No WT, No HSPA
- Monitoring system PWS S without WBL, no ICM function
- Monitoring system PWS S without WBL, ICM reset
- Monitoring system PWS S without WBL, ICM shut-off
- Monitoring system PWS S without WBL, full ICM function
- Monitoring system PWS N without WBL, no ICM function
- Monitoring system PWS N without WBL, ICM reset
- Monitoring system PWS N without WBL, ICM shut-off
- Monitoring system PWS N without WBL, full ICM function
roverman
I think that mine literally says nothing but "WBL" And it doesnt work :) At least I think it doesn't work. If it worked, I'd be able to check the air pressure through the menu on the display, right? I'm not sure why the GAP guys started ignoring me, they were very helpful at first and then just stopped. I think I'll bug 'em again.
Not if you have a 2013 or earlier. The TPMS works just fine on my LR4, but is only designed to warn me if a tire is low on air. There is no info screen where I can check current air pressure. I understand that feature was added in later model years (starting with 2014s, I believe), under the same Settings submenu where you also check your motor oil level.
I never attempted to completely disable TPMS myself, whenever I got a warning in the past it was always for a good reason - a nail or something else causing a slow leak - unless I am aired down while off-roading, but then I know to just ignore it. I do have "Spare tire monitoring" turned off via IIDTool (I store my oversized tire partially deflated as it wouldn't fit under the car otherwise), but I still get a warning to check the spare tire every time I start the car. It only lasts a few seconds before extinguishing, so I have learned to live with it, but the routine obviously didn't disable monitoring of the spare tire, at least on my model year.
roverman
That's interesting. I'm almost sure that prior to turning it off, there was at least something in that sub menu that said 'pressure ok' or whatever (2013). Are you saying there is no way at all to know if it's even working? (short of letting the air out of a tire I guess, maybe I'll try that)
I honestly don't care if it works or not but not knowing things bugs the crap out of me. Must. Figure. It. OUT!!
A562NV
