Point me to some Black 18” or 20” rims for LR4
roverca
San diego
Why would you need spacers for using RR 20's? I have a LR3 and I had some never used take offs from a RR supercharged that I got off Craigslist. Looked good handling was improved on the freeway. Couple years ago went back to the 18's with 27/65/18 KO2's and johnson rods.
Asilver
New York, NY
You will need spacers. 1".
Thanks for the response. It's what I had expected, but was hoping to be wrong.
LR4s have larger break calipers which require a higher offset to clear.
An LR4's brake calipers aren't bigger than a Range Rover's. The large brake calipers are why you need to run spacers on 18" Land Rover wheels; doesn't seem like the brake calipers are why you'd need spacers for 20's.
Rover 4
West Palm Beach
running the 20's with 2.5" lift rods, and 255/50/R20 KO2's
NASdiesel
You need the spacing to run a larger or wider tire to clear the suspension. For instance the 275/55R20 toyo mud terrains.
Alvin Mercer
I’m going cross eyed trying to figure out what to do. We have a 2011 LR4 and needing tires bad. I hate the 19” wheel because there like 3 options and I’d like a little more meat.
Thinking about doing a 2.5” Johnson Rod lift and 20’s with 275/55-20 or around that (what’s largest size for 20’s?). Maybe 18’s but the Compo looks like the only option.
So questions is what wheels. I want black and have been looking at powder coated wheels on eBay, but they seem to all be RR wheels. Found these and like them but idk if they’ll work. 50mm offset...
Will 35mm offset work in an aftermarket wheel?!
Help!
View attachment 9012 View attachment 9013
I used some 20" stormer wheels that I found at a great price and had them refinished to matte black. Used with the Pirelli Scorpion All Terrain Plus, 275/55-20 (a newer offroad tire)
I put a pic here of before also, with the 19" black wheels from the LR4 ( I have the LR3)
