Clunking persists after new bushings
Winston9932
we have a 2015 Land Rover lr4 that has made a persistent clunking when traversing ramps or curbs at an angle. For example, if you pull out of our driveway that has about a six inch ramp drop to street, there is a clunk that seems to come from front. Dealer replaced front bushings under warranty, saying they had separated. LCA fine, as were tie rods.
We also own a 2016 LR4 and have owned two more prior - unique sound.
Any ideas?
What front bushings were replaced? The rear lower control arm bushings are the likely culprit.
You mentioned LCA were fine? I doubt dealer pressed new bushings into the LCAs
Winston9932
See invoice attached of work done
Wow they did just the bushings. No problem as "vehicle is OK at this time" lol
TrinidadLR4
NE Washington DC
Looks like they just replaced the fronts. Most likely, the rears need replacing too. Also, wonder if the ball joints themselves are going bad. At this pt, might just need new LCAs.
BikePilot
Golden Colorado (USA)
Sway bar bushings are known to fail and can clunk. Since it's under warranty I'd just take it back and let them deal with it.
Big Sky Country
Part number shown (LR073366) is for the rear bushing of the front control arms, which AFAIK is the one which usually wears prematurely and causes clunking.
