DRL's and GAP tool - 2012 LR4
nolift911
This just happened to me. I was about to load some household trash from the garage into the LR4 and I got the dreaded “nobody’s home” response when I pressed the lift gate button. No click or anything.
I broke out the IIDTool and sure enough there was a fault code for a short in that switch. I cleared it and the lift gate worked just fine. I still need to determine if there’s an underlying problem back there, but as you said, it got me back in business in the moment.
Mine just went south also - interesting that you could fix it with the tool - I had to climb back there and break in, replaced the switch, and motor.
Annapolis, Maryland, USA
It may have been a complete coincidence. The fault was for a short. I cleared it in the app but admittedly I didn't expect it to fix a physical fault/short if one existed, but the fault disappeared after I ran the routine a couple of times. Liftgate is still working fine.
johnnwalters
My dealer did it for $100. At the same time I had them program the trailer lights after installing the kit myself. It seemed pretty standard for them to make any programming change for $100 since they were already in there.
nolift911
I installed the trailer wiring kit and did not have to program - was it for a brake controller?
Jimmy Brooks
Pasadena California
I have a 2010 HSE LUX. I’ve actually thought about this a lot and just to make sure I’m hearing this correctly I can enable daytime running lamps with this correct?
spookie721
Yes, you can enable the Daylight Running Lights with the Gap IID toll. Options for Canadian or Scandinavian version. 2 min job.
2005 LR3 4.4
