There she blows, (maybe coolant crossover)
Jimmy Brooks
Pasadena California
Well, it looks like my car decided to relieve its self of all of its coolant after a drive to one of my buddy’s houses. I’m guessing it’s the inevitable coolant crossover pipe but I’m not too sure. I’ll keep you guys updated when I hear from the shop on Monday. Good news is my oil temperature was still half way in between cold and hot
If it's the crossover, let us know how old it was.
djatkinson
djatkinson
I can relate!!
The Achille's heel in our case was a catastrophic coolant leak. This has happened to me, on my 2006 LR3, with 194K miles. We were driving, not too far from home and had the alert: "Reduced Engine Performance". Little did we know (no warning lights or gauges, due to engineering/placement of heat sensors), that we had a massive loss of coolant from the plastic reservoir. This causes head gasket failure, and you can imagine the rest. These engines (4.4L; 5.0L are even worse!) die quickly from over-heating! From what I'm told by the techs, there is no work-around to overcome the engineering flaw. Bottom line: check your engine frequently for leaks, faulty hoses, etc.. And, if you see the warning light: "Reduced Engine Performance", pull over immediately, and shut down the engine; hopefully, fast enough to save the engine!
Jimmy Brooks
Pasadena California
Just a question for everyone who had a shop do this repair, how much did they charge for both crossover pipes and did they do anything else when they did this job?
