Increasing approach angle?
powershift
Nevada
After a big storm the road out of my campsite was washed out in several more places, one of which was the first real challenge I had in the LR4 off-road. Trying to get to the other side the plastic under the front-end started scraping. I started looking at front skid plates but then started wondering if I need a new bumper instead. The factory skid plates work great, I think they are pretty tough metal and I've made a mistake or two that gave me more confidence in them.
Some aftermarket front skid plates for the LR4 span past the radiator which I like but they have cutouts for the air knives and what I need to do is climb through washouts and kind of plow the front-end over the bank maybe lifting it off its tires even though there isn't enough clearance. Driving like that I can risk tearing the plastic apart and under the bumper its all plastic.
Then there are skid plates that look nice and strong until they show the 1/4" dia. mounting studs and that is clearly the weak point. The pic blow shows the area I'd like to clearance where the dirt scrapes are on the plastic. Has anyone modified the front bumper to get more clearance? Any solutions to get more clearance there?
Land Rover Joe
Oxford
Dear @powershift
Great questions and while I run the OEM front skid plate (I believe it is from ManTech and called the "Steering Guard"), the gang at Tactical 4X4 makes a whole steel front bumper with winch mounts and such which supposedly improves your approach angle. See - https://tactical4x4.com/index.php/product/lr4-front-winch-bumper/
I have never used it (that much steel out front is not legal in Europe) but folks who bought it did like it. To get those better angles, some trimming and minor modifications will be necessary.
That said, the OEM plate is really great...I have literally "crushed rocks" (not on purpose but pretty impressive none-the-less)!
powershift
Nevada
The ManTech Steering Guard looks nice, but I've only seen pics of it fitted with an aftermarket bumper. It doesn't look like it would fit stock.
I've used both aluminum Front Runner and the ASFIR sump guards. They're both pretty stout, banged through a lot of things with them and kept my truck intact. Aluminum is lighter if you're into the whole weight savings.
Rover Range
Texas
Once the suspension is in in extended off road mode. You can get additional ride height.
The additional lift can be requested once the height change LED has turned off. Press and hold the air suspension switch in the up position for 3 seconds while depressing the brake pedal. A chime from the instrument cluster will sound to confirm that the process has been completed.
powershift
Nevada
That would be sweet, but on mine I tried those steps and there wasn't any response after pressing the brake pedal and UP on the suspension switch for 3 seconds while in off-road mode. Should those steps work on all LR4 years?
Rover Range
Texas
All LR4s can do this.
You have to wait until the suspension has completed the raising process in off road mode.
The raising indicator light has to be off. All doors closed.
Jimmy Brooks
Pasadena California
I love my ASFIR skid plate. I’ve banged mine up a bit but it still holds strong. I think the highlight of it is the value. I got mine for $319 and it covers the front where the tow eye is, the radiator, and the entire engine all the way to the sway bar. I remember seeing the other skid plates like front runner’s which only covered the tow eye and radiator and that being $500, probably more expensive now.
