Persistent misfire under load only
Jimmy Brooks
Pasadena California
or if your fuel adaptations are not readjusting for some reason.
This is what I’m aiming on. I emailed Gap, they just sent me an update for the G3. Really hoping that I gain the ability to reset fuel adaptions because I think this could possibly be the issue. Probably a long shot though.
I’ll keep you guys posted, I’ll be back with the car on Saturday.
Jimmy Brooks
Pasadena California
Ok, updated the tool and can see everything now. The car is running rich… super rich. The first screen shot is before I cleared the fuel adaptions. The second is after I cleared them and took a short drive around the block. Additionally, I pulled up some voltages that seem a bit high but could be normal. Please let me know what you guys think.
powershift
Nevada
How do you know its rich? Back when I drag raced we data logged only at WOT (99% as shown on 0 based index) to determine if it was lean, rich, timing advance, knock, ******, etc.
Jimmy Brooks
Pasadena California
At idle when these cars are warmed up they I believe the general rule of thumb is long term-short term=<+/-10%. As you can see mine are way past that point.
greiswig
SW Washington
Hard to interpret the numbers without RPMs, etc. My basic understanding is that if you have a vacuum leak, your STFT should drop as you raise RPM and the proportion of leak to metered air reduces. So maybe try that? Otherwise I wonder if maybe the O2 sensors are sending the wrong data?
Jimmy Brooks
Pasadena California
I’ll get the car warmed up and take some logs. Any specific RPMs you want me to hold it at? I think someone said 1500 but when I try to hold it there the rpms like to fluctuate 100-200 rpms up and down.
I could be wrong but wouldn’t it mean that both O2 sensors are bad since both banks read rich.
Also could you pull up the same voltages I did? I think both of those sensors that are reading high voltages are this same sensor here.
Here is a YouTube video of the RPMs fluctuating
high positive = too lean, i.e., car is needing to add 20%+ fuel to try to reach the target air/fuel mixture. Car must be warmed up or it won’t be in closed loop, at which point it is just using scheduled air/fuel. After warm up, take the fuel trims at idle and holding steady at a couple of higher RPMs (around 1500, around 2500). Record with RPMs as well. If the fuel trims tend to get closer to zero with increasing RPMs, that points to a vacuum leak. If it gets worse with increasing RPMs, that points to fuel delivery problems.
