2012 LR4 Speaker Replacement
Robin Parsons
Austin, TX
Godard? Jave the same problem with left and right doors on 2014. Both tweak from being blown, mostly with audio books or telephone speech, very annoying. Both have been replaced once. Does anyone know a higher wattage/better quality speakers to avoid having to do this again?
DaytonaRS7
Indian Trail, NC
weird, i was just thinking about replacing a couple of my door speakers and tailgate subwoofer.
i cant find any information on what ohms to get though.
for the lowest speaker in the doors i was considering:
https://www.crutchfield.com/S-L06lp...AnFCL23gn0zdEtftfe9FrhVxvYaV6CbxoC1skQAvD_BwE
for the tailgate sub:
https://www.mtx.com/35-series-3510-04s-10-300-watt-rms-4ohm-car-audio-shallow-subwoofer
does anyone have any info of the ohms for the OEM logic7 system?
Did you get the subwoofer for your tailgate? Mine sounds terrible and I think I will replace it since I just replaced the upper tailgate actuator and have the speaker exposed. Looking for a replacement speaker but not sure if using non OEM parts require additional workimgs.
Sent from my SM-G965U using Tapatalk
DaytonaRS7
Not yet.
I plan to use non oem parts, and I'm sure a minor wiring terminal changes will be needed.
From my understanding, a 10" low profile subwoofer is needed. The issue is, I'm not sure what ohms to use.
Can you check the impedance of the existing subwoofer with a multimeter?
Indian Trail, NC
Not yet.
In piecing together from other threads on this site I have seen people using 4 ohm
roverzac
East Coast
I want to add this here for anybody combing through. The 10" HK subwoofer has dual 4 ohm voice coils. This is the case for my 2013 with Logic 7. I believe the same woofer was used for several configurations. I haven't been able to figure out it's power capabilities, though.
The subwoofer in the tailgate, right?
Jimmy Brooks
Pasadena California
I know the Logic 7 system became more powerful I think post 2011. if I remember correctly they went from a 14 speaker 480w system pre 2012 and to a 17 speaker (added tweeters to the mid range center speaker in the front and the 2 surround mid ranges in the back) and to an 825w system. I would imagine that they would've swapped the sub for something that could handle the increased power.
I ended up adding a 10' JL 400w powered sub to mine and turned the sub down on the normal system to save wattage for the highs. the bass is pretty awesome when I want it to be but can also sound like factory with a bit deeper bass.
