I've got some weird electrical stuff going on, so I figured (1) I may as well document it here as I go and (2) it's likely that I'll get some good input from all of you.
We've had our 2015 LR4 HSE for at least 4 years and it has almost always given the low battery, start engine warning. Side note, the auxiliary battery was dead when we bought it and the previous owner said, "My dealer said it doesn't do anything except make the ECO function work. I don't like that anyway, so I never replaced it." I took him for his word on that. I removed the battery so it didn't leak/explode/whatever and thought maybe it was "stealing" power from the primary battery which would cause the low battery warning. No issues (that I could tell) and ECO never worked, but I was fine with that as well.
Battery low continued even after good charges and clearing battery memory/resetting with ODB scanner. I then had battery replaced and all was well for... a few weeks. We never had an issue with the vehicle starting, so attributed it to something odd with the auxiliary battery being gone/missing. A couple years went past and this battery started failing on a regular and tested bad by part store. Replaced battery again.
Good for a couple of weeks again and then low battery warnings started again. I then had TCM (shifter) fail to shift and my research shows those are touchy/sensitive to voltage issues and low batteries. hmm... (I sent TCM to Xemodex to be repaired. I have that back and it works, but I also have another used one that I have rigged with a zip tie to pull the shift lock mechanism. I'm going to keep using that until I get to the bottom of the power issues.)
LR4 sat for 5 days and battery was dead. Started to realize I've got a parasitic drain somewhere, so I started testing a few things with multimeter. Disconnected negative cable and tested amp draw between cable and negative post. The vehicle is drawing over 0.5 amps with everything off. yikes...
I pulled the plug on the BMS on the negative cable and tested battery voltage. On the battery I had 12.9v and on one of the pins of the BMS I only had 6.64v. Is this normal? It doesn't seem like it is. I found this post (older model and BMS is different).
Mine looks like this and if I put multimeter on the top pin inside the plug is when I read 6.64v.
Next steps:
1) Ordered a new Exide EK151
2) Test all fuses
3) Do I need a new negative cable end and BMS?
4) Anyone worked through a parasitic drain and have a good approach to narrow and pin it down?
Next steps:
2) Test all fuses
