I recently got an XLifter, and the documentation is a little thin. So I have a couple of questions.
1. If you install the XLifter system, you end up with basically two sets of controls trying to run in parallel, right? For example, if you have the stock buttons set to off-road mode, and the XLifter set to -25mm, what happens?
i.e. does the XLifter overrride whatever the stock system is doing once it is installed, so that -25mm is set relative to the calibrated 0mm setting (ignoring how the stock controls are set)? Or does it set -25mm relative to that new off-road height?
2. I also can’t figure out how to find the WiFi password.
3. I noticed on my setup, when I first lowered by 25mm, it appeared to lower the front, but not the rear. Yet when I tried that trailer assist setting, it definitely lowered the rear, by a lot. Does that mean it didn’t calibrate properly or something?
