Broncoman95
Hello everyone,
I have a land rover LR3 2006 V6 and have been dealing with a couple of strange issues with the air suspension. Ive researched all over for this issue, but Can only find 2 things about it and the forums just get cut off and end with no real help.
When starting the car, I instantly get a suspension fault when the compressor kicks on. I have scanned the codes, and I get c1a35 - Reservoir valve, and then shortly after, if I clear it and try and raise the car, I get C1A31 (front left corner valve). Upon these issues, I have put a new compressor, dryer, front valve block, and reservoir valve block in, and these codes and issues are still present. The weird thing about it all is that the front never really lifts, but the rear would lift and go into off-road height despite the fault. It wasn't until recently that the front lifted up a little bit.
I'm at a complete loss here... Ive checked a decent amount of things for leaks, but I'm starting to assume I'm dealing with an electrical gremlin. The rear would go up all the way in off-road height, but the front wouldn't move at all. Now, since putting in new parts, the back doesn't go as high when in off-road mode while the front stays around access height. Yet, at one point, I got the front to lift, which I Hadn't been able to do before. Even now, when it's at its normal height, the front is higher than before the new parts, but still not functioning properly. Ive read that "c1a35 - Reservoir valve" is typically an electrical fault, and when it fails, it causes other things not to function properly, which may be why I'm getting a front corner valve code. If anyone has any help, advice, or information, I would greatly appreciate it. I will take anything I can get.
In regards,
Jack
In regards,
Jack
