Showoff Your LR4
Phil-C
Beaufort SC
Here’s mine.
Adding rock sliders and Hella lights soon. Parts are here, just waiting to put them on.
Willi
Brazil
Brasil landie here. Had some fun in the mountains in Minas Gerais. A lot of very sticky mud there. Camped inside the car for a couple of days to see how it would go.
Couple of mods on the green lady:
- Mantec raised air intake
- Frontrunner roof rack
- Frontrunner aux battery support
- CTEK aux battery controller setup
- Headlight/Tail light guards
- Aliexpress reflective all-around window cover (cheap, surprisingly good quality)
- RAW Offroad 18" wheels (these barely fit, had to trim the brake calipers), since it's impossible to get a compomotive or terrafirma set around here, had to work with what we had. People use these on Dodge Rams 2500 with different bolt pattern around here, so I think I'm safe.
- 285/65 R18 BFG KO2's (great tires, lkess noisy than I expected). These are rubbing all over so some mods are needed to provide enough clearance. Should have gone with a 60 instead of a 65, but oh well.
Future planned mods
- light bar on the rack
- work lights on the sides
- rocklights underneath
- solar panel in front of the rooftop tent to use as a windbreak
- rear wheel carrier and steel bumper
- front winchbumper with a winch
- aluminum aux diesel tank in the spare tire space
- saddle water tanks on the space under the passenger hooked up to a seaflo pump
- heat exchanger on the coolant line that runs to the rear aircon unit, so the water in the tanks can be used for a hot shower if needed
- shower enclosure on the rack;
- compressed air reservoir (probably will mod a small fire extinguisher bottle hooked to the CKMTA12),
- sleeping platform for the trunk with a drawer and drawer-fridge, maybe some space for the CKMTA12 compressor and a power inverter.
Kelly Barrie
Los Angeles
Been absent for along while, beauty has 130K on it now, but hasn't let me down yet. Installed rear tire carrier, factory day running lights, dual zone fridge, 18" with 285/60/18 Toyo RT's
puckball55
south florida
i have 105 k on my 2013. i live in fla so i went with bridgestone duelers , great tire. just took a 900 mile trip through nc to lex ky and back. truck ran like a champ. even in 28 degree weather up there. just recently replaced compresser and two front struts and suspension maintained perfectly. though about trading it for range rover but it really is a great truck and the land rover dealer only offered me 4 k for it which was insane
sdtim
Oceanside, CA
Day 1. I have realistic expectations.
Jimmy Brooks
Pasadena California
Not sure if I ever shared these, took her up to mammoth (where my profile picture was taken nearly 7 years ago) to see the snow and hit the slopes. Crazy amounts of snow, pretty surreal experience, especially for California.
landylou
