Chip in windshield
Lakeray
OKC
Have a 2016 LR4. Got a chip in the windsheild about 1/2 inch big. Can I just get the chip fixed or will it bother the electric grid (heated windshield)?
Thanks,
Ray
Al Pizzica
PA
If I were you I would try to fix it first. There is little to lose vs a new windshield. I live in a winter area and even then almost never use the windshield heat (garage) so if it died on mine I wouldn't be too put out. Up to you on that end. I doubt the repair epoxy will affect the grid compared to the physical damage that may have been caused by the chip.
All they do to fix a chip is put a liquid plastic resin in the chip and let it cure under suction so that when it solidifies there are no air bubbles caught in it. If your heated windshield still works now, it will continue to work after the fix.
djkaosone
'11 LR4 HSE LUX 5.0L V8
SoCal
Just be careful that some repair kits may have conductive properties and if you have a heated windshield, that can cause issues down the road.
landylou
