IID app crashes when looking at certain live values
Nechaken
Colorado
2016 w/ VAP tune.
Using the IID tool app on iphone, when I look at camshaft degrees (or camshaft adaptation value, not in car right now), the app crashes. Kicked back to the home screen. Same thing happens when looking at any of the torque values (estimated, demanded, calculated, etc) under the Engine Petrol setting. (Notably, the torque value under the transmission can be viewed fine). It appears that other live values work fine -- temp, voltage, boost, etc., etc. I've restarted the iphone and it keeps happening.
Just curious if anyone else has experienced this, in particular the VAP folks @Fuji4 @16FujiDisco ?
GAP is pretty good about getting back to you if you email them. First, though, is to make sure you've downloaded all the firmware updates to the iiD tool.
Nechaken
Colorado
Thanks. I thought I had done an update earlier, but will plug it in and check it out.
16FujiDisco
Nashville, TN
@Nechaken so far I’ve only used the live values for the things that have worked for you and I haven’t had any issues. So far I haven’t used any of the more ‘serious’ live value look-ins
PE_in_UAE
