AC not cooling - B11FF-85 (2E) code
M32H32IS
Texas
Apparently there’s an issue with air conditioner refrigerant pressure according to my GAP tool. Any idea what causes this or potential solutions?
f1racer328
AZ
You can use the GAP tool to pull up the refrigerant pressure. Should help you diagnose a bit more.
M32H32IS
Texas
My pressure reading according to GAP
Rover Range
Texas
For that DTC, a few things need to be checked.
Test the refrigerant system for proper freon charge.
Check the condenser and hoses for damage or restriction.
Test the air conditioning fan for correct operation. With the engine off, should spin with some slight resistance. With the engine running, should have good air flow.
You can install a new refrigerant pressure sensor as necessary. Those rarely fail though.
More than likely, you will have to install a new HVAC control module.
tragic1
