According to the Manual the following is a gauge of time. Doesn't look hard by looking at it either....
Remove radiator shroud, remove fan, remove belt, remove the water pump, then carefully (read extreme) scrap off all of the old gasket, then apply new gasket (a little blue gasket maker never hurts) to hold gasket in place, replace water pump, belt, fan, radiator shroud..... start and check for leaks, have one on me.....
26.50 WATER PUMP
26.50.01 Pump -water -renew .............................................00.60
26.50.01/01 Pump -water -renew -with unit removed ..............00.15
26.50.02 Gasket -water pump -renew ...................................00.60
26.50.08 Seals/’O ’ring -water pump -set -renew ....................00.60
