Crazy to consider new engine in a 2016 LR4?
DavidSG
Virginia
Have a 2016 Landmark edition with 86K miles on it. Cosmetically it's in great shape - paint still looks like new, has all the bells and whistles (HD pack, towing, vision, rear entertainment, etc.). Just did new front brakes and new tires and lower control arms.
It has never over-heated (as far as I know) and haven't gotten any check engine lights, but I sense that I'm on borrowed time. For the past 2 years I haven't been able to get a coolant issue sorted out. I had the water pump and crossover pipes replaced a couple of years ago. 9 months later, the coolant reserve seemed close to empty. They repaired a rear heater something under warranty. 9 months later same thing. They pressure tested it and couldn't find any leaks. 6 months later same thing. Thought I saw faint signs of white smoke coming from the exhaust. Spoke with a few mechanics and consensus seems to be (without any physical tests) it's a head gasket issue and only real fix is a new engine. Haven't done any further tests to confirm, but they said I should dump it at CarMax while I can still get something for it.
I know "rebuying" this LR4 for $35K isn't the most rational thing to do (call it $10K I could get from CarMax plus $25K for new engine). I know it's not a classic or anything but I love the look and feel of it (and wouldn't consider buying another LR4 because who knows how long that engine would last). Just seems like the perfect 3rd car to have until the wheels fall off (I would get a new daily driver and only put a few thousand miles on this per year going forward) if I had confidence it's not a ticking time bomb after replacing the engine.
Crazy or not?
DavidSG
Virginia
Yeah I wouldn’t just go straight to engine replacement. But assuming it was a head gasket issue with no reliable way to fix that short of an engine replacement, curious if a replacement engine (not repaired - basically a factory new / rebuilt engine) would be reliable for relatively low mileage going forward or another disaster waiting to happen.
Edit - just spoke to a Land Rover specialist (one of the two Land Rover specialists I spoke to that said it was likely a head gasket issue). I will probably take it to him next week so he can run 1) coolant pressure test (already had this done a couple of times with no obvious leak) and 2) a combustion test to determine / confirm if there really is an internal engine issue.
Appreciate any other recommendations on how to diagnose this properly!
powershift
Nevada
I would have replaced my engine after I bought it in '23, but I didn't need one. You probably bought it with the coolant problem preexisting.
The LR4's are all worth more in actuality than they are on paper and that is a good thing because it brings the cost down. In my case from $60k MSRP 13 years ago.
tragic1
