Just as many of you guys did, I ordered a pair of DDMTUNING 35W kit. It worked perfectly for about a week, then starts to shut off one at a time. In addition, only one will turned on, either left or right. Left for Monday, right for Tuesday, and both for Friday. Sometimes a turn off turn on will correct the problem, but most of the time there are no luck.
Any of you guys had/having this ?![]()
i just remembered i had some firing issues during colder weather. when the temperature was in the 30s, the lights might misfire during a cold start. the trick is to not have your light set on auto. then on a cold start, start the car and warm up or drive around for 5 min before you turn on the lights. this fixed my issue during the winter. when they misfire, you have to restart your car in order for them to fire correctly.
