Fuel Pump
msmplumbing
I need to replace a fuel pump on a 96 Disco. I searched on line and found 2 kinds of pumps. Does anyone know which type is correct? Evaporative fuel system or??
Thanks
Go to British parts of Utah and see their write up on the 2 different pumps. As a 96, you should be using the older style unit, the new pumps are vin specific so if you want to check, get your vin, go on line and read up.
deeb
i just dealt with a similar problem. easiest thing to do is pull up your carpet in the hatch and take the cover off. you can look right at the fuel pump, if you see 2 electronic connectors its the newer evap setup.
but like mike said, its a 96 so it should be older fuel pump system.
good luck
chad
STQAddie91
