Location of used t-case amd transmission
richterjustin08
Need some help guys of where to locate used t-case , and a transmission... I have a 98 disco, 4 speed....
Not sure which one I will need , its at the shop right now , should know what problem is with mine soon...
Just want to be ahead of the game on where to locate either or.. thanks guys..
Give Nathan a call in my Signature... he has a few around, or knows where to get them.
So, just curious, what is wrong with your truck and be specific, how many miles on it and when was the tranny/tcase last serviced?
richterjustin08
Mike the temp sensor went off one time , and that was a long time ago and then this past Thursday of went off again.. when it went off I was driving on the highway when it came on... As I got into town at a light it started smoking... Come to find pit the thing that was smoking is their a sensor on the side of the case, right behind the t-case driver side .. that's where the smoking was coming from...
Now she sits in the drive way and the shofter on top will not go into gear... When u drive just a little bit out of driveway it sound small but ugly...
The crazy part is before this happened while driving on highway , when wanting to past someone it will not move, its like it has pressure and its trying to get the power to pass but won't go... Tachometer does not drop when u floor it to pass someone its just lurk come on come on... Like a build up, but never gets that kick... U understand...
Consider sending me a PM with your number so we can talk.
richterjustin08
Hey guys found the problem, took the plug out of t-case.. hardly any gear live dripped out.. I continued to take the plate of and on the plate it was covered with metal shavings.. a lot ... I moved the main gear and it has a little play in it...
So you haven't been keeping an eye on your levels.
Not sure where you are located but, Paul Grant is a great guy to buy from, might want to give him a call at 203-7701699.
So when was the last time you actually gave your D1 a major service?
1 Oil filter, K&N 3001 or Mobil 1- 301
1 Factory air filter
6 Qts. of engine oil
2 feet of 3/16th vacuum tube
2 feet of 5/16th vacuum tube
6 Qts. Of Vavoline’s high mileage Dextron 3 ATF
7 Qts. of 80/90W synthetic gear oil, 85W/140 for HD use
3 Pints of Vavoline’s DOT 4 Brake fluid
4 Qts of synthetic ATF fluid
1 bottle of Lucas P/S stop leak
1 bottle Lucas Tranny Stop Leak
2 Gallons of Peak or any green or yellow coolant, don’t use Dexcool
1 Bottle of Lucas Power Steering additive
1 Bottle of Lucas Transmission additive
1 Can of Spray Carb. Spray
1 Can Of Brake cleaner
8 Spark Plugs, I use Bosch Platinum Plus 4's
1 Set of Magnacor or STI 8mm plug wires
1 Serpentine belt
2 Bottles of SeaFoam gas additive
1 T/Stat
1 bottle of WaterWetter or Purple Ice
1 new fuel filter
Hoses and belts, as necessary
Front and rear wheel bearings and all seals for wheel bearings and swivels if necessary
60,000 Mile Service or Major Service for High Mileage Used Vehicle just purchased
Bleed the brakes
Flush and change the power steering fluid adding one bottle of additive
Service the tranny adding one bottle of additive, change the filter if necessary
Change the coolant and t/stat
Do an engine flush before changing the oil
Do an induction cleaning
Clean the throttle body
Add fuel additive to full gas tank
Change both of the diffs fluid
Change the t/case oil
Replace the plugs and wires
Replace the air filter
Lube all the drive shaft grease fitting including the 2 slip shafts
Do full inspection of brakes, hoses, bushings etc.
Repack or replace the 4 wheel bearings
Service the swivel balls, reseal, refill and adjust the pre-load
Replace the fuel filter
Inspect and replace all hoses, brake, coolant and cooler lines as necessary
richterjustin08
Yes mike I didn't check it when I got it... I admit... Don't give me that hard of a time.. lol
But thank you for all the info mike... And joey as well thanks.. I'm going to do all these checks after I put the t-case in.... I will let yall guys know...
