Long crank, no faults
16FujiDisco
Nashville, TN
I’m not 100% sure but I would suspect Denso; someone else me be able to confirm or correct me. I would also trust NGK or Bosch as an alternative, but they could also be OEM
greiswig
Supporting Member
Supporting Member
SW Washington
Definitely try a new plug for this test, too. I've seen plugs fail internally in some odd, temperature-sensitive ways.
16FujiDisco
Nashville, TN
Yep, that’s it. There is one for each cylinder, and make sure you get the right ones for either V8 or V6
Longtrail
Ann Arbor
Great - Thanks Jimmy; just never really paid attention to this change with direct injection engines so every time I kept reading the word coil I was scratching my head, I get it now :) - Thanks for confirming.
Good luck by the way getting to the bottom of this issue; it would be great if it's as simple as this part!
00Jam
