loss of power when engine warm up..
S
semuta
I have a 99 D2..I have been losing power after my engine warms up..Its fine when its is still cold but after a couple minutes of driving I start to lose power.. the moter seems to be Ideling fine and doesnt miss fire at all..it starts fine and all that, I let sit a couple of minutes before I drive any where..and its fine till the temp. is up..if I come to a stop and take off again there is hardy any power...any help here?
Check to see if the CATS are glowing.... sounds like your cats may be going bad.
S
semuta
I hope not...lol... I cleaned the MAF and cleaned the STEPPER MOTER both really really good, the moter had all sorts of black gunk in it..and that seemed to fix the problem..I drove around for a while and got the engine all nice and warm, and it seemed like it was running better and better as I was going... So I really hope that all it wiil take..But my SES light is still on..could that just be an emission thing?
How many miles?
If under 86k, then probably not the Emissions...
S
semuta
well your right about the CATALYTIC CONVERTERs...after I drove around town for awhile and engine started acting up again...So when I got home I checked under the truck and the CATS were glowing so red I could roast a mashmellows on them...sucks!!! I like doing thing myself So how hard is it to change out the CATS?
Depends on if you have a sawszaw (spelling) and a mig welder? Or if you want to spend the almost $800 on a new 'Y' pipe.
S
semuta
what do you think about after market Y pipes and CATS? I found some around $350.00 to $400.00 online
As far as I am aware, there are only a couple companies that make Y pipes for the Rover and unless you buy used, you not going to find them for $350 - 400... but I have been wrong before.
I would recomend finding a good muffler shop (I don't mean Midaz or similar chain), a nice out of the way shop that just thinks Land Rover is made by toyota.... Ask them to fit in two new cats. Should cost more than $200 that way.
SulliMtn
