Joeyrc76
Yesterday, I was replacing my lower control arms or lower wishbones and what is typically the most difficult parts went pretty smoothly. I decided to go with the upgraded polly bushings since I heard they’re much less problematic than the stock parts. I was able to remove all the bolts and the only thing left was to pull out the Ball joint. Here is where the drama came in. I could not seem to be able to get the part that get it off. I tried all kinds of angles but It wouldn’t budge from the housing. I’ve seen videos where it comes off super easy but mine seems to be seized somehow. Anyone have the same issue or have any suggestions for folks who may want to do the same? I tried a pry bar, wd40, anti-seize, I tried using the jack creatively, beat the crap out of it to shock it loose, and none of it seemed to work. The worst part is that the issue is on both sides. I finally gave it and taking it to the mighty expensive dealership tomorrow.
