CRYA
Awesome thanks buddy. For the 6mm tubing, that's gotta be nylon and it's 6mm O.D. correct? Source from Grainger also?I carry a full 3/8 socket set with deep and shallow sockets, extensions, elbows, 1/2 torque wrench with a 1/2 to 3/8 reducer, ratcheting wrenches, thin wrenches, and just make sure your kit has T20-T55 sockets and 8mm-19mm sizes, including 16mm and 18mm.
As far as suspension issues go, build yourself an EAS bypass kit. Use a 6mm straight union, 6mm tubing, and a 6mm push fit schrader valve. Plug 1 ft of tubing between the straight union and schrader valve. In the event of a catastrophic failure, unplug fuse F3 and F26, cut your airline above the brass fitting, plug the union into the strut(s), and pump up each corner. When you're in a safe area to fix the issue, just use the union to combine the existing 6mm tubing.
The only 290 PSI rated straight union: https://www.grainger.com/product/LEGRIS-6mm-Plastic-Union-1DED8
