Polybush kit from Atlantic British
e24kgold
Does anyone have or have seen the polybush kit from Atlantic British. Seems like a good move vs. the stock bushings. Price is $450 and looks to include every bushing on the rig. Bet you would pay a ton for labor though. I think I might pull the trigger.
http://www.roverparts.com/Parts/9746.cfm
2005 LR3 SE V8
allodial
i just replaced rear bushings in sway bar... cost like 250 at dealer to install a set of 10 bushings.... goto a local shop to have them install i'd say..
I just had my bushings replaced a few thousand miles ago....but as soon as they go out again I will be snapping these AB Polybushes up and having them installed in lieu of the OE bushings.
jjvd21
I noticed their LR3 kit is the red firm bushing set. Anyone know how this would compare to OE? Also, would polybush last a lot longer?
hell pie
The claim is that the polybushes can last up to five times longer than the OE ones. I had no idea what polybushes were before yesterday, but after doing some reading on the internet, it seems there are tradeoffs with the firmer ones. You get tighter suspension and handling which is good for on-road, but can be uncomfortable off-road. It also means that the polybushes are redirecting the stresses to the vehicle chassis, body, and other components.
I think my front bushings are going bad, so I'll get a set of the polybushes some time this year before I get new tires. Which means I'd better start saving up.
calibre
It sounds like there are blue, orange and red polybush sets that provide different comfort levels. Has anyone tried the blue or orange? Or just the red? How does this red set ride? Too stiff?
I really like the idea of not having to change bushings a lot....
I'd really like this solution to be vetted through the LR3 community (here and abroad) before I pull the trigger, but when I do I will most likely go Orange.
e24kgold
I just had my bushings replaced under warranty... When i need to replace them again I will go with the poly set. The one that is most comparable to stock ride
nwoods
Can't hardly last shorter!
e24kgold
you got that right...had poly bushing on my old bmw...lasted forever
00Jam
