power steering pump
dragan
Ii everybody
Did anybody have bad experience whit power steering pump.
I notes leak in January vent to the dealer and I gat new power steering pump.
In April power steering pump is wet again .went to different LR dealer and got second power steering pump .June again leak .Haw LR dealer can’t found the problem, maybe I need to replace pump very 2 month
Thanks :confused:
davez26
Not a common issue.
To quantify statistically, we sold a fair amount of vehicles, and I don't even have the P/S pump on the acvtive system. That means I've never ordered one, or at least in the past 14 months as the system wipes the # out after no activity.
Very interesting...
GrahamWelland
It would seem to me that they're fixing a symptom temporarily and not the cause ... maybe the dealer techs need to look a bit further beyond the obvious?
zdas04
I once heard a compressor-operator tell his mechanic "I replaced the solenoid 5 times and it still won't start", the mechanic responded "maybe the problem isn't the solenoid?". Seems like this anecdote might apply.
David
angasreid
My power steering is going out too. It's difficult to turn the wheels, slight whine, and spotty in some areas. It's strange too, often while driving it will just pull to a side. Glad I bought that extended warranty.
It will be in the dealer monday.
Disco Mike
If it turns out to be the pump, Rover will replace it under warranty, go have them check it.
dragan
Thanks guys I agree
I think may leak cam from above PS pump bat I am enable to found.
Above is the A/C compressor can hi may have leak? Will go Monday to shop
Last visit in shop mechanic tell me hi don’t see leak I need cam back after 500 ml
angasreid
So mine ended up being the rack and pinion. Apparently, it's broke. Glad I have that extended warranty.
To update this post of mine, the rack and pinion wasn't the problem. It was the u-joint on the steering column.
dragan
I left my LR3 in shop to fix oil leak.
Mechanic tell me hi will replace steering box and 2 hose to bee on safe side.
Look to me hi can’t found the problem so hi will replace everything.
I hope this time hi will fix leak
MArsel
