2000 DII with 114K
I have been having a shuddering/vibration comming through the drivetrain as I drive. This only does it under power (ie if it is vibrating and I shift into N it goes away) it seems to change frequency as the truck shifts. I have checked the u-joints (front and rear) and they seem tight. I suspect the transmission, mainly because about 2 mos ago I replaced the filter and as much fluid as possible. I only drained out 5 quarts so that is all I put back in. The old filter and fluid looked good, although there was a fair amount of metal on the pan magnet. This problem did not start immediatly after the service it just started about a week ago (oddly the same time the weather got cold @ 20F) I am thinking I am going to take it somewhere and have the tranny flushed and refilled. I just wanted to check with you guys first.
Any ideas are greatly appreciatied.
Mark
Mark
